My problem is when i want to run the slave more with respect to master channel then in configuration window of the slave the parameter of maximum modulo i have to keep as per the ratio defined. suppose my ratio for the slave is 4/3.I am using encoder of 1000 pulse for slave then for maximum modulo value of the slave i have to write
1000*4/3=1333. then the slave is running perfectly in the ration defined. but if i have defined ratio for the slave is less then the master ( i.e. 4/9 ) then what i have to write for the max modulo value. by entering this ratio value slave is not rotating atleast one cycle. after rotating half cycle module shows "deviation
fault".
fault".
