R
Machine underwent Major Overhaul. Control System is Mark VIe. Electronic simulation tests for HP overspeed were successfully done. As per OEM recommendations, HP Overspeed Bolt Test is not mandatory to avoid Machine Overstress.
Actual Electronic Overspeed Test also was NOT Successful as machine tripped 100 rpm before the test level during test and OEM recommends to put the machine in operation without doing it again.
What are the Overspeed tests mandatory after Major Overhaul?
