We are looking at using the Twido Compact 16 Pt modules that come standard with 1 serial port. I would like to set up an RS-485 multi-drop connected to a Modbus TCP to Modbus RTU bridge (Lantronix type). Has anyone tested a similar configuration? We would like to be able to have a SCADA solution like Wonderware be interfacing Modbus TCP to the PLCs and be able to simultaneously access a PLC on the multi-drop using TwidoSoft. Also, what's the deal with the mini-Din connector? Do they make a mini-Din to terminal adapter or something that will make an electrician's job easier when setting up the 2-wire RS-485 multi-drop? I understand that if you get the 2nd option port they have an adapter that has screw down terminals on it.
Thank you in advance for any help!
