I have to measure a metal sheet and to cut it to a specific dimension. For this small application I use the following: - ---Twido PLC TWDLCAA10DRF-XBTN200
To measure the metal sheet length I use a robber wheel mounted on an Heidenhain TTL 1000ppr encoder.
Can I connect the TTL encoder to the very fast counter inputs on Twido PLC?
If not what type of encoder I should use?
Thank you in advanced for your short answers,
Cristian
Cristian
