Twido with Modbus/TCP
1
12add3
I have a Schneider Twido TWDLCDA40DRF PLC with no ethernet port. I want to add ethernet port to existing PLC and use Modbus/TCP communication protocol to communicate with SCADA software running on PC.
I need help to select the right components.
I selected this hardware:
1No 499TWD01100 connexium communication module (it supplied with TWXCARJP03P cable, Connexium <->twido)
1No TWDNAC485D serial adapter to Twido
1No ethernet cable (Connexium <->PC)
The right choice is
That´s all you need.
If you need help just ask
Good Luck
