L
I'm trying to connect HMI XV-252 from Moeller to Twido by Ethernet. Seems like IP addresses are good, because from Windows CE on the panel i can ping ethernet ports of Twido.
I'm using Galileo for doing visualization. I've entered variables as 16 bit-array, and attached variables to the buttons. (%M1 & %M2 on the PLC).
The starting address @ Galileo is M0000.
After uploading project to the PLC I'm getting "WSA: Connection refused" I now i can't really find an explanation why.
Is there something wrong with the ethernet configuration of the Twido or with the address range in the panel?
Cheers
Cheers
