Two NIC's running in NT4
John Dunsmore
Is it possible to run two network cards in NT4 Workstation in a novell environment?
One card (10/100 Compaq NE3121) for IPX/SPX and a ne2000 for TCP/IP
Tried to set bindings for the card's but nothing seems to work!
Can anyone help?
I have been told yes this can be done by the Admin at my company. I will see on monday if I can get the answer for and maybe give some instructions.
>Can anyone help?
L
There are a few things to check first.
1: Is netware client installed,if so have you setup login server{netware) in control panel?
2: First set up netware side of netcard. I had to remove the other card first before it would work for me.
3: After this you should be able to login into Netware server.
4: Reinstall ne2000 card in machine. In Network (Control Panel) goto network propertys and check adapters and add netcard. And add your second card and choose your protocal(TCPIP) Make sure you set up DNS and WINS. IF you use DHCP then make sure you have added local machine name first to DHCP server.Then go and check "Multihome" box. This will allow you to have two net cards with different/same protocals on same box. Hope this helps good luck
