Our plant has 1 TXP machine (OM/OT/ET). The machine turned off few days back. We found out that some power capacitors on the Motherboard were blown. We had a spare Motherboard of the same brand. So we replaced it. After restoration, we started the machine. The system started normally and so did the OM. But the archive configuration is lost. All the trends are white and are only showing data for the last 22 hours. Before the Hardware failure, the system was showing data since 2007. Is there a way to restore the archive? Is there any support platform outside Siemens that supports TXP?
