P
G'day List
Application is fitting a Fax machine onboard a mobile machine. Trailing cable is used for the telephone line through sliprings, this is
causing problems with the Fax. I read on the list some time ago of the mercotac mercury commutator, if this would be of any benefit to overcome the problem Iam not sure. The other suggestion is the use of radio modems, if anyone can be of
assistance it would be appreciated.
Phil Dryburgh
Phil Dryburgh
