Using outputs on Mitsubishi PLC to control motor
F
Fran Repash
I'm having trouble getting outputs to control an inverter to regulate speed of a motor. I can run the motor from the PU operation of the inverter but when I switch to the external mode, the corresponding LEDs on the PLC light up but there is no output voltage. I believe the program was tempered with but I have no means of interfacing. Any suggestions.
