G
This is a great site!
I am looking for a way to divide the flow of liquid (water) with a PC. The requirement is for a type of valve that will accept a 1/2" or 3/8" port from a water pump that is rated up to 1100 GPH. The valve will divide the flow of water between two output ports. The flow out of one of the ports will be much greater than the other, but not off completely.
I'm hoping to find a valve that can be controlled with +12V pulse width mode or analog DC. Is there anything such as a variable 3 way valve? Or is there another device that I should use? I considered using a regular 3 way value with a solenoid and controlling it with PWM, but I don't think the valves I've found can be switched so quickly.
Anyone have any ideas?
Graham Best
Graham Best
