I have a GE-IP Versamax IC200CPU001 PLC. The controller has entered into a fault state (reason unkonwn). As a result, the serial communication between the controller and the Programming PC cannot be established to look for fault tables or other diagnostic options. The CPU LED status is as follows:
Power: Stable Green
OK: Stable Green
Run: Off
Fault: On
Force: On
How can i resolve this fault problem? Is there any way to restore the cpu to factory defaults?
Power: Stable Green
OK: Stable Green
Run: Off
Fault: On
Force: On
