R
Hello all,
I was wondering if anyone has any experience for calculating the range for a d/p cell on a Venturi installed in a vertical line? The transmitter is a rosemount and is measuring the flow of lean froth which has a density of around 0.9 s.g into a vessel. we are having problems accurately setting the range and what would be the best method of zeroing the transmitter?
also does any one here have experience with measuring flow off of a vertical line, which instruments are you using?
