We have a Goulds 5 CHC, 6 stg pump. Run by a 15 Hp, 230 v 60 Hz motor with 47.4 max Amps, 3450 RPM. It is driven by a 50 Hp Altivar 630. The problem we are having is every time we try and up the flow rate (pumping water), the VFD trips on overcurrent. We are currently stuck @ 7 L/s when we know the pump is capable of much more. We have changed out the motor and pump as well as new cable down to our deep well. And it still does the same thing!! What could be the reason for this? There are no breaks in our lines. The nameplate of motor is set into VFD with most of the correct info but the RPM does not match the nameplate, it is set to 1778. Is this the reason we can not achieve the desired flow rate? This is all new to us and we can not get anywhere with the suppliers. Any help or suggestions would be greatly appreciated thank you!!
