We are trying to use the feedback from a small "S" shaped load cell to measure the force applied by a piston to a sanding belt. The feedback
system works fine (. i.e forced against a static stop) until the rotating sanding belt comes in contact with the sanding block attached to the piston. It will feed back acceptable readings until about 14 lbs. pressure. After that it reads 14 lbs no matter what the actual pressure is.
Any suggestions???
Art Bourdeau,
[email protected]
Phone
518)765-3667
Fax: (518)765-4033
Mobil: (518)573-4745
Fax
518)765-4033
Any suggestions???
Art Bourdeau,
[email protected]
Phone
Fax: (518)765-4033
Fax
