hi
i am using vijeo citect 7.4. i generate a report automatically using a trigger, but the report generated in the .rtf form which any body can change the values in the report. so i want to either make the report in the read only form or convert it automatically to pdf +.
i've another problem i am trying to write a string in the report using the form {tag_name:############} where the tag_name is a variable string memory where i store in it a word "starter". when the report is generated, only two letters "st" is generated.
can any body give me a solution for these two problems?
thanks in advance.
thanks in advance.
