F
I'm using the MSComm to send and receive binary data to a video server. The sending part
works fine, but when it receive more than 8 bytes, the input variable only keeps the bytes
over the eighth byte. Please, can someone tell me where I'm wrong??? These are the settings and the OnComm part:
MSComm1.CommPort = 1
MSComm1.Settings = "38400,O,8,1"
MSComm1.InputMode = 1
MSComm1.InputLen = 0
MSComm1.RThreshold = 1
MSComm1.SThreshold = 1
MSComm1.DTREnable = True
MSComm1.RTSEnable = True
MSComm1.NullDiscard = False
If MSComm1.PortOpen = False Then
MSComm1.PortOpen = True
End If
Private Sub MSComm1_OnComm()
Dim buffer As Variant
Dim Arr() As Byte
Dim i As Integer
Dim iTemp As Integer
Dim sTemp As String
Dim strINPUT As String
Select Case MSComm1.CommEvent
Case comEvReceive
Do While MSComm1.InBufferCount > 0
buffer = MSComm1.Input
Arr = buffer
For i = LBound(Arr) To UBound(Arr)
iTemp = Asc(Chr$(Arr(i)))
sTemp = Hex$(iTemp)
If Len(sTemp) = 1 Then 'For display in a text box
strINPUT = strINPUT & "0" & sTemp & " "
Else
strINPUT = strINPUT & sTemp & " "
End If
Text1.Text = strINPUT
Next
Loop
End If
Dim Arr() As Byte
Dim i As Integer
Dim sTemp As String
Case comEvReceive
Arr = buffer
sTemp = Hex$(iTemp)
Else
End If
Next
Loop
