Hi.. Facing problem with Voith I/H Converter. Output oil pressure fluctuates about 0.1 Kg/cm2, leading to servo opening of steam Turbine.
Model BSG-B10113.
Model BSG-B10113.
Thank you for the replySorry for late reply.
Actually its a 50 MW QJPS, China Turbine. The PID controller is integrated in Woodward 505.
Servo mean the final control element for stram to turbine inlet.
The secondary oil faces fluctuation after the voith received from vendor. Calibraiton part is OK.
