Volumetric flow measurement
P
praveenkmr
Can somebody suggest a suitable in situ sensor for vacuum column hot well gas volumetric flow measurement in a 10" pipe?
Normal flow is 600 Kg/hr.
Molecular wt (23-39)
Pressure (Nor - Atmospheric, Max - 3.5 Kg/cm2), Temp (Nor 40 & Max 200 Degree C).
The gas contains wet H2S (.03 - 23.33 % Wt).
