I'm new to PLC and MODBUS, need helps and advises from gurus here.
Currently I have multiple EGXs connected to a ethernet switch. So, now I required to pull data from these EGXs and display on the SCADA.
The PLC model I'm using is Modicon M340 with BMX P342020 CPU. It has 2 ports, ethernet and modbus TCPIP, and the ethernet port is already used to link to the SCADA.
Now, if I wanted to pull data from the EGX, can I read the data by connecting an ethernet cable from the modbus TCPIP port (on the PLC) to ethernet switch? Or I required to add an additional BMX NOE0100 ethernet card to pull data with IO scan?
