after opening the valve's VA13, VA19 in air purge system, why there is a lot of water around it?
I think it should be the air compressor condensate after turbine shut down.
am i true?
would you please suggest a way to remove this water because it can cause corrosion in the regulator valves and VA13, VA19.
best regards
am i true?
best regards
