P
Hi
I will like to have information if this product is available.
I bought a condo in Venezuela.
There we have a cold water tank inside.
When we take water from home, the motor start and when we close the tap, the motor stop
now all tanks from all condominiums are filled each day at around 6:30pm by a giant tank (probably underground).
The problem is we have to switch off the motor (have to be there at this time or switch the valve if we plan to not be there) and turn an valve, then water flow in the water tank until the float (bulb and not electronics) stop the water.
It is the general and basic system used in South America and I heard in few other countries too, as you can see very primitive.
Now I will like to know if someone or a company have the brightest idea to build a electronic system to make it all completely automatic
I means, timer, open-close valve and switch on/off the motor.
Because of course the motor switch have to be on once the tank is full, the motor not turn but in standby until someone take water from home, and stay open until no one need anymore water, then the motor power off, (not the switch)
Can you tell me something about it.
This is a blue plastic tank about 7' long, plastic.
Thank you
Thank you
