weighing indicator programing
E
eng/amr fouda
I'm trying to design a weighing indicator and make amplifier card and convert signal from a/d using ads1251 with serial date output. you can say the data is ready to read but i have to problem.
1- i read from ads1251 data but it's a big number and variable while the load is stable. i want to know if the reading is correct and it's normally to be variable while the load is stable?
2- want to write a program to calculate the final weight in kg. what are the program procedure can i trace to do and what is mathematical calculation can i do to sure accurate weight?
i need a help from who know how to do that
thanks
