I'm currently learning the basics of Level Measurement, and at the moment I'm stuck on Dry & Wet legs. If anyone could walk me through this example problem (it's not a homework problem, or for any type of project). it would be greatly appreciated as it will fill in some blanks for me.
If you are wary that this could be a homework/test problem, I would also greatly appreciate any links that will explain the 'basics' of using Dry and Wet legs. I have already read the brief explanation on Dry/Wet legs from www.omega.ca however it hasn't given me enough info to answer this example problem.
Here is a picture of the problem:
<b>http://i53.tinypic.com/2d2fyhv.png</b>
Thank you for your time.
