I want to build a pop-up target for my home rifle range and I need a recommendation for a servo motor that is appropriate for this project. It needs to be powerful enough to simply raise a plastic target from the horizontal to the vertical position and back to the horizontal when hit. The target measures 20"w x 48"h and weighs less than a pound. The motor will be mated to a worm gearbox and I imagine that the servo will rotate in opposite directions when raising and lowering the target which is attached to an arm which is connected to an axel running through the gearbox. I want the target to be raised and lowered in 1 second or less.
I do not wish to have any kind of oscillating transmission which is why I am considering a servo motor, however I am open to other suggestions.
