Win2KS auto log on
  • Thread starter Donald Pittendrigh
  • Start date
Donald Pittendrigh
Hi All
Can someone please put me out of my misery and tell me where in Win2k server the password logon gets set to a default user name and password so the machine can automatically boot and run up when the power is switched on.
I know it is possible as I have done it before, but cannot remember where, there is no users icon in the control panel as in Win2kPro and in the computer manager under users I do not find a possibility to set the default logon.
Donald Pittendrigh
Jacki Wenzlick
Donald,
Microsoft KB article Q234562 (How to set up Windows 2000 for Auto Login) says this is only available for Win2K Pro and is not an option on Win2K server or Advanced server. But maybe there is some super-secret registery way around this.
good luck,
Jacki
You will find all of the appropriate settings here.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
You may need to add DefaultUserName, DefaultPassword and AutoAdminLogon. They are all REG_SZ data types.
G
gino mettepenningen
To enable automatically logon, do the following:
(click on start-Run and type) Start Regedt32.exe,and then locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon
Using your account name and password, double-click the DefaultUserName entry, type your user name, and then click OK.
Double-click the DefaultPassword entry, type your passworde, and then click OK.
NOTE:if the DefaultPassword value does not exist, follow these steps:
Click Add Value on the Edit menu
In the Value Name box, type Defaultpassword, and then click REG_SZ for the Data Type
Type your password in the String box, and then save your changes.
Also, if no DefaultPassword string is specified, Windows automatically changes the value of the AutoAdminlogon key from 1 (true) to 0 (false), which disables the AutoAdminlogon feature.
Click Add Value on the Edit menu, enter AutoAdminLogon in the Value Name box, and then click REG_SZ for the Data Type.
Type 1 in the String box, and then save your changes.
Quit Regedt32.
Click Start, click Shutdown, and then click OK to turn off your computer.
Resart your computer and Windows.you are now able to log on aytomatically.
It's werk, i have done this a few time's for a visualisation.
Goed luke, gino_me[email protected]
Bob Peterson
Its a registry entry. I forget where it is but MS has a knowledge base article on it.
Bob Peterson
Michel A. Levesque, eng.
You have two good explanations on how to go about setting up the AutoLogon in the registry. Don't forget to add the DefaultDomain key also if you want to login to a domain.
I have been doing a lot of this lately... if this doesn't help, let me know.
1. Reboot the PC
2. Create ntautologonuser Start>Settings>Control Panel>Users
and Passwords
Add ntautologon user
Uncheck User must change password at next logon
Check User cannot change password
Check Password never expires
3. Configure ntautologonuser Uncheck startup box
Start>Settings>Taskbar & Start Menu?
Check first four checkboxes. Uncheck fifth checkbox.
4. Configure Auto Logon
Run regedt32
Select HKEY_LOCAL_MACHINE
Open SOFTWARE\Microsoft\Windows
NT\CurrentVersion
Click WinLogon
Set AutoAdminLogon 1
Set DefaultDomainName to Computer Name
Set DefaultUserName to ntautologonuser
Paul T
G
Gabriele Corrieri
Hi Donald,
you can set auto logon without password in Control Panel / Users and password, by unset the checkbox 'For using ...'
Now the system will logon without requesting username and password, but it will logon as Administrator, take carefully that in this state the user (or any application that runs in this session) could be destroy the system.
Hope this helps you.
Gabriele Corrieri
W
Wayne Curnuck
You can always simply get the TweakUI as supplied by MS. It does this as well as packaging a few other 'tools' and keeps things easy to use with a
simple interface.
Wayne Curnuck
Donald Pittendrigh
Hi All
This problem is solved, it seems there is no simple point and click place to make the setting, I was referred to the correct registry settings by a list member, I looked it up in my registry manual and was resolved to edit the registry and set things up the way I wanted, when another list member sent me a neat little utility which does the setting for you.
Thanks to all who responded to my plea for sanity preservation.
Donald Pittendrigh
Donald Pittendrigh
Hi All
Mmmmmm..... I believe in the original post I did say that the operating system was 2000 Server, or Win2kS as shown in the subject line. This of course does not have Users etc. as an icon in the control panel, but rather it is found under computer manager, which does not provide the opportunity to make the settings you have so kindly described.
For general info, if 2000 server is installed it does provide the option to set a default user, when it asks the question,
"should windows always assume the following user has logged onto this PC"
Or allows you to set an admin password. It seems this is the last time you get the option to make this setting in plain English, and should you forgo the privilege, you end up with the problem I have described. Fortunately some kind lister,
has sent me a very useful app. That makes the setting for you and it was extracted from the NT resource kit.
Nice day
Donald Pittendrigh
>1. Reboot the PC
> Start>Settings>Control Panel>Users and Passwords
> logon
Armando ABRAHAM
Open the windows registry (regedit.exe at command prompt) and go to
KEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWSNT\CURRENTVERSION\WINLOGON.
There, you'll find all that you need to do the autologon
(defalutDomainName,DefaultUserName, etc).
Best Regards.
Armando Abraham
Easiest way is: Control Panel> Passwords & Users
UN-check the box that tells the computer to require a login. If it is already unchecked, check it (trust me). OK out if you checked it. Return to it and UN-check it. When you hit OK this time, the computer will prompt you for a default user and password to be logged on...
David
David, you're right, this is what I tell people to do in Win2K and Win2KS... It seems MicroSoft bungled the interface for this option.
Kelly
Donald Pittendrigh
Hi All
I raised this issue within the last year on this forum, and I still can't find the users and passwords icon in the control panel in WIN2KS which according to the topic heading, is what this query is about.
A search of the archives will show who did respond with the right answer, I cannot remember who it was.
Donald Pittendrigh
for a default user and password to be logged on... <
P
Paul Watts (aka Bodwad)
In regedit
Goto Run:
Type Regedit and hit enter
move through this path:
Check The Key 'DefaultUsername' is correct to your username
Check (or create a text key) called 'DefaultPassword' again enter correct value
Add a new key (String Again) and call it 'AutoAdminLogon'
Set That Key to '1'
Restart and Voila =P
