WinCC as Modbus Master and a DCS slave
SunilB
Background: Siemens PCS7 ver 5.1. with a 414 CPU and CP 441-2 having X-27 (RS485/RS422) interface module configured as Modbus Master. The X-27 interface has a 15 pin connector. I would like to emulate the DCS slave with an emulation software I could download from the net.
First question:
The problem is connectivity of X-27 to com port on the PC. What kind of pin-out I can use (w.r.t. either of 9 pin/25 pin com ports). I guess I need an RS485 to RS232 converter. The only converters I could get my hands on had 9 pin/25 pin endings.How do I handle the 15 pin thing?
Another question: If I want to use WinCC as a Modbus Master:
i)How should I go about simulating the slave with the emulating software residing on the same PC as WinCC(as component of PCS7).
ii) Would I need a license for WinCC as a Modbus Master.
I hope I am lucky with answers as a newly registered troubled soul!!
Thanks for reading
SunilB
Z
Zan Von Flue
Hi
For the first question see the HB:
"http://www4.ad.siemens.de/csinfo/li...419/CP441_d.pdf?func=doc.Fetch&nodeid=1135661":http://www4.ad.siemens.de/csinfo/li...419/CP441_d.pdf?func=doc.Fetch&nodeid=1135661
The pinout 15pole is there, about P.270 . Normaly a RS485 can also RS232 when the R(B)- from both are connected.
but for the rest I don't know.
try
"http://www4.ad.siemens.de/csinfo/livelink.exe?func=cslib.csinfo&siteid=cs&la":http://www4.ad.siemens.de/csinfo/livelink.exe?func=cslib.csinfo&siteid=cs&la
and search. maybe it'll help
later
zan
M Modbus 0
N Modbus 0
A Modbus 2
K Modbus 1
A Modbus 1
