S Thread Starter Shalin Sep 11, 2008 #1 Is there a driver available within the Siemens WinCC HMI package for communication to a Modicon Momentum PLC using MODBUS interface?
A AR Nov 5, 2008 #2 Hi, I tried, but I have the same problem. If anybody finds a solution, please email to me: albertras at gmail. com Thanks, Al
S Satish Bhat Aug 19, 2009 #3 WinCC version 5.1 does support modbus master driver. I am not sure about the later versions of it. You can use this driver for communication with any PLC which is supporting modbus. Regards, Satish Bhat
C COMMUNICATION BETWEEN WINCC &MODBUS\ May 19, 2011 #4 hi i think if use converter rs485 to TCP/ip,you can will use modbus TCP driver in wincc.
A automationcorner.com May 24, 2011 #5 I advise you to use an ActiveX component embedded on your WinCC. You can use one of our ActiveX (serial or ethernet). Visit www.automationcorner.com
