I'm using wincc flexible 2005 advanced pc runtime. and I want to save the data logs to oracle database.
in wincc flexible help files, siemens says:
______________________________________________
Databases tested and released for WinCC flexible:
MS Data Engine 97 and MS Data Engine 2000
MS Access 97 and MS Access 2000
MS SQL Server 7.0 and MS SQL Server 2000
I'm sucessfully save the data logs to access and ms sql server, but failed to save it to oracle. when I start up the runtime, I can see a message on the runtime screen says"log initialization ended, all logs ok", so I think the odbc connection to oracle is correct, but the wincc flexible runtime is failed to create the table in oracle database.
hope someone here can help me,
capture
capture
