Wireless Ethernet radio needed
Jonas Berge
I need a licensed Ethernet radio for the 400 MHz band. It shall be "industrial grade" with coverage in terms of kilometers.
All I see on the web is 900 MHz, 2.4 GHz, and 5.8 GHz.
Please advice if you know of any. Vendors, feel free to contact me directly.
Jonas Berge
[email protected]
Wireless Ethernet is a contradiction in terms. You probably need a TCP/IP capable radio. Ethernet - IEEE 802.3 is only defined over real wires, whereas Wireless LAN is IEEE 802.11 - several flavors)
Meir
Proxim used to make some 400 mhz stuff, I think.
Not sure about the range. They may have some lying around. Check proxim.com
Jonas,
Contact Motorola regarding radios in the UHF band (400MHz) to see if their radios will pass TCP/IP protocol - you are probably looking at 802.11a/b/g flavors, if you need immediate answers contact
TLECC at 303-697-0440 ask for MIke Richardson, he can fill in csome of the details regarding Motorola radios will work in this scheme.
matt
Jonas -
I would assume that you already have a valid FCC license, since getting a clear 400 MHz frequency can take up to 2 years. Try Zetron - they manufacture communication systems licensed to Motorola as well as their own branded wireless products that work nicely with Motorola products. <http://www.zetron.com>. Also, Black Box makes some Wireless Campus Network Hardware that they could design around your frequency requirements, and it shouldn't be overly pricey.
D Networking 0
S Networking 0
I Programmable Logic Controller - PLC 0
B General Automation Chat 10
A General Communications Chat 6
