I am going to China next week to investigate a complaint from a customer of ours about the "slowness" of the Wonderware InTouch 8.0 HMI that was installed for them a year ago.
Firstly, the specifications of the computers:
Win XP SP2 (Chinese version)
1 GB Ram
Hardware RAID card with two 40GB hard drives in Mirror (RAID 1).
- 134 screens
- Alarm Logger
- Custom ActiveX controls used to communicate to robotic controllers ProfiBus I/O
- Siemens S7 PLC using ProfiBus.
- Ethernet connections to robot controllers for File transfers (Job Files and backups)
The customer has continued to complain about the slowness of 5 of 9 HMI computers. These three are no different to any of the other computers, but these 5 are used most often. Other HMI computers in the plant have less IO communications, but also run the same version of the hardware (plant general spec) and InTouch software (just different screens).
List of things that I am going to check, and I would like to know from others for items that should be added to this list:
1. Memory performance (specifically Physical Memory Available/Commit Charge Peak).
2. Conditions of the Raid 1 system (faults, etc.).
3. Check items in the Windows Events Logs.
4. Check for any issues with limits on the Alarm Logs for InTouch.
5. Virus checks (computers are connected on plant wide network with CISCO switches, but separate to office network).
6. Hard Drive sector conditions (maybe using Spinrite (http://www.grc.com)).
Thoughts? Is there a known performance issue or “wall” that one can get to with screen objects that could impact HMI performance?
Thanks for any input.
Shawn Rimmell
1 GB Ram
- 134 screens
- Alarm Logger
Shawn Rimmell
