Hi all,
I'm upgrading our Wonderware from ver. 5.1b running on a Windows 3.1 machine to WW ver. 7.1 on a Win NT4 (SP6) machine with an ISA SA85 card (Modbus Plus). This machine also has an internet connection via an ethernet NIC card. I loaded Modicon's MB+ Driver Suite 4.20 and was able to see all the nodes in our network. Then I loaded Wonderware and it's license. Next I loaded our existing application at which time WW converted it to this 32 bit version and all seemed well. Then I loaded WW's MB+ I/O server and entered the topics, slave path's and stuff the same as the old version was. I thought everything was going well but was not getting any live data. I viewed the Event Log and it said CARD SA85:0 Not Found, Bad NCB_LANA_NUM device not found. So I tried changing the address on the card (and in the MBX configuration) from D0000 to D8000 then C8000 and I get a message on startup that there was a driver failure. The Event log says "Test validating that MbpDrv0 was really a Modbus Plus adaptor card failed. The device is assumed not to be a Modbus Plus device and will be deleted." So what the hay am I doing wrong here? Should I just keep trying different addresses for the card or is there something else I'm missing here?
