Wonderware SuiteLink
swiredtw
I am using Windows 2000 on the two machines I plan to network and Wonderware 7.11. I need information on configuring the two PC's...
Suitelink is only from WW. So if your networking 2 InTouch nodes you simply need to have networking setup using tcp/ip. Suitelink will use TCP/IP and the only thing you need to do is select Suitelink in the Access Name in both applications.
Hope this helps!
