There are a Bunch of Software i use to test my Modbus communications, one of them is a command line application in both Linux and windows called modpoll 3.10 - FieldTalk(tm) Modbus(R) Master Simulator, another one is windows and that is Generic Modbus Tester, by "Schneider Electric" and or VB.NET / C++ / C# Various Software we Have Developed for testing Various ModbusTCP and Modbus RTU scenarios, now Almost all of these Solutions work well with 4 different makes of PLC's including Automation Direct Productivity 2000 along with Click-Plus Without Problems. then we get to the AB-Micro850 and hit a wall , do we actually have to put Modbus Instructions into the Controller to make this happen.? i could maybe see that PLC to PLC but not PC to PLCWhat software instructions have you programmed to initiate comms. with your external device.
A few more details on configuration and the external device(s) may be helpful.
O | Interference on MODBUS wiring when working on inverters | Modbus | 9 | |
R | Modbus Communication Partially Working Through RS485 | Modbus | 5 | |
J | Linux Command Line Program to Check if MODBUS Sensor Is Working | Modbus | 1 | |
S | MODBUS Working | Modbus | 1 | |
E | MODBUS/RTU working with serial protocols(RS485,RS422) | Modbus | 1 |
by Seth Price
by Bob Odhiambo
