Hello community,
first of all introduce myself, I am an electronic engineer which develops projects of new machines for the electronic sector.
I would like to ask you a question because I do not have much experience in this.
Well, let's see if I explain myself well.
We have integrated an application with a conveyor system, the PC SW sends the information in an XML file, we need to be able to "translate" that file so that the PLC understands it and can work and we also need to be able to "translate" the information from the PLC to XML so that the SW understands it.
We use a Panasonic PLC and they tell me that through a module programmed with Python could do this...
Any idea how to communicate PLC-Pasarella-SW so that they understand each other?
The XML file is raw, does not use server or anything, just the SW creates it with some parameters and the PLC has to interpret it and vice versa.
Thank you very much.
I hope I have explained well
