YASKAWA V1000 Multi function input
Darryll
we are first time to use the YASKAWA V1000 drive in our company and it was complicated to us than the other inverter we use it before (OMRON V1000). Our problem is when signal come from the PLC going to the S5, our machine run a jog mode. when we press the button in HMI it is happen when the photo sensor sense the conveyor, but is not like before in other INVERTER we use (OMRON V1000). when we push the button in HMI our machine run continuously and that sensor only give signal to the PLC to trigger a cylinder, and it will stop only when we will not push the button to HMI.
i want also to know what is the difference between YASKAWA V1000 to OMRON V10000
[email protected]
