Yokogawa error message
N
Nacer
I try to load my FCS unfortunately I did not come, every time I test, a error message appear <pre>
"Starting generation Mon Aug 08 09:50:32 2011
ERROR:pRGID:0x2011:BKCECODE:0x20000116:TagTblSearch
ERROR:Internal Error:BKCECODE=0x20000116:TagTblSearch:TagName=L024FIC201-SV
---- ERROR = 2 WARNING = 0 ----"
When I removed the tag "L024FIC201-SV" I got a new error message
"ERROR:DelTag Error
---- ERROR = 3 WARNING = 0 ----"</pre>
Help me please.
Steve Martin
You've basically created a tag without it being registered in the taglist. This can be done if you try messing in the project directories. e.g. copying between projects in windows explorer.
The only way I've managed to fix this is manually copy the taglist itself - the file is in the ETC directory and its called TagRef.rdb. I also had to copy the PlantClass.l file too. After that no more errors. :)
