F
I am having trouble locating a pressure switch to mount on a bag filter system for zinc chloride. The temperature is 70 - 100 degrees F, 100% (or close to it) solution of zinc chloride. I need two contacts, one to alarm at 20psi and one to shut off the pump at 30psi. Also I need local indication and NEMA 4X enclosure. The problem is finding a pressure switch that is made of material compatible with zinc chloride. I have tried SOR, Turck, and United Electric but don't get a comfortable feeling from them. Does anyone have experience with filtering zinc chloride and using pressure switches with it? This is a duplex bag filter system, 7500gpm, mag-drive pump, skid mounted. Manufacturer of system will not install a pressure switch. Fred Chwalek Applications Engineer Beacon E-Commerce, eFilter Division Voice: (704) 398-7916 Fax: (704) 398-7822 Email: [email protected]
