R
Respected Sir,
I am trying to Transfer Data over Telephone Line through Modem. Following is some Technical Information that I’m currently using.
- VB6.0 and MSComm Control 6.0
- All Default Property Values of MSComm Control has been used.
- My Modem is “ MR56PVS-RSI 56K Speakerphone PCI Modem ”
- I’m Issuing Hayes Command (i. e. AT Commands) to my Modem. Also, Default Settings of modem are not disturbed.
- Also, the contents of Input Buffer of MSComm control are being displayed in a simple Label Control. Note that I’m using a Timer control, with delay of 1 Second, which fetches Input Buffer of MSComm Control and sends to label control for display.
But During Testing I’m facing some Problem. Let’s call “MR56PVS-RSI 56K Speakerphone PCI Modem” as Modem-A and Remote modem as Modem-B.
Here is how it goes -
Situation I -
Modem-A calls Modem-B by dialing appropriate Telephone Number (ATDT XXXXXX)
Modem-B receives the Ring & responds to Modem-A by using command ATA.
While the Two Modems Do the Handshaking I can hear (at both places) the typical weird noise coming from Modem’s Speaker. After some time I get the “Connect 9600” message at both the Modems.
Now, Modem-B sends some message to Modem-A. Modem-A can successfully receive this message in the Input Buffer of MSComm Control and message is displayed in label control that I’m using.
But, the problem lies here. Modem-A now tries to send some message to Modem-B. But I can’t see any message at Modem-B’s MSComm Control-Input Buffer. I also can’t see any disconnected message or “No Carrier” message from both the modems, meaning connection is OK.
Note - By ‘Modem-A or B doing some action’, I mean my VB application issuing AT command to Modem-A or B. I’m using Same VB application at both Ends. I’m using a Textbox Control where AT commands can be entered, thereby allowing me to give AT-commands Dynamically.
Situation II -
Now the Roles of both modems has been Interchanged. Here Modem-B is caller and Modem-A is receiver. But In both situations only Modem-A is unable to send any message Or may be Modem-B is unable to receive any message but can send successfully.
I am looking for a solution, which will enable me to communicate in both directions. Your co-operation is highly appreciated.
Thanking you,
Ravi
Situation I -
Situation II -
Thanking you,
Ravi
