Monday, October 21, 2019
Error Message Ratio
Could anyone classify the percentage of error message for good, standard and bad communication.
If a Modbus RTU device makes 5 to 8% error message by CRC frame check, it is normal or bad for a multi-drop network with baudrate 9600bps?
Thanks.
Hung Lam
By Michael T Mellish on 8 August, 2002 - 2:55 pm
Your error rate is high indicating three possible problem areas:
1. Your driver is not always correctly calculating the CRC-16 so some messages are rejected.
2. Your host is issues new commands before a response is received. These additional characters are crammed into the modbus slaves serial port buffer, overwriting parts of the uncomplete message (so it is corrupted & failes CRC check)
3. You have communications cabling issues which are disrupting the proper data flow.
A clean installation will run less than 1% errors.
