Please bear with me as I'm new to pretty much everything I currently have my hands in. I have a Data Acquisition system set up to compare actual ppm to a quoted ppm. This will in turn drive a light tree giving management a visiual aid in running assembly lines. I have the project set up with an SQL statement to read from the DB and the DB logger to write. When I run my project, I receive the following error:
"The Microsoft Jet database engine cannot open the file 'E:\xxxxx.mdb'. It is already opened exclusively by another user, or you need permission to view the data."
I have admin rights on both pc's and the domain. No other users have rights to the DB. I'm not sure what I'm missing. If I run the SQL statement alone, it reacts normal but in Cimplicity, I receive the previous message. If anyone is familiar with this problem, please respond to my email.
Thank you
Thank you
