K
We use 6.6 kV Squirrel Cage Induction Motor 4pole 6.6kV star connected in our blast hole drill application. The motor is a 500 hp motor, driving an air compressor at one end and set of hydraulic pump on the other side. The motor is started using Auto Transformer starter connected as Korndorffer Starter(closed transition). We find flash over taking place while switching from 80% tap connection to 100%. The flash occurs at Star contactor of the vacuum contactor or line to ground in the contactor. Can some one explain any such experience and possible solution.
K.Gurumurthy
Manager Splecial projects
Ingersoll-Rand India Limited
Peenya Industrial Area
Bangalore 560 058
INDIA
Ph: 91 80 8395791 extn 3103
Fax: 91 80 8394651
email: [email protected]
mobile: 98440 30417
K.Gurumurthy
Bangalore 560 058
INDIA
Fax: 91 80 8394651
mobile: 98440 30417
