<p>Following are several old-fashioned, simple but effective non-electrical methods to estimate a motor's load-factor:
<p>1) Load estimate by slip.
This was discussed in the Fri, Dec 27, 3:30pm response to the thread "Efficiency Calculations of Old Motors!" A fluorescent lamp was used as the strobe light.
<p>2) Load estimate by resistance.
Determine stator winding resistance for "hot" and "cold" conditions. Load-factor, LF, is the ratio of measured temp-rise, Tm, to rated temp-rise, Tr. Then, for copper and aluminum windings:
<pre>
Th = (Rh / Rc) x (Km + Ta) - Km. Since,
Tm = Th - Ta, then solving for LF,
LF = Tm / Tr = (Th - Ta) / Tr, yielding,
= (Kr - 1) x (Km + Ta) / Tr, where,
Ta = ambient temp when motor is 'cold'.
Th = ambient temp when motor is 'hot'.
Tr = motor's rated temperature-rise.
Kr = Hot to cold resistance ratio = Rh / Ra.
Km = mat'l constant, Cu=234.5 & Al=228.
Rh = stator 'hot' resistance, Ohms.
Ra = stator 'cold"resistance, Ohms.
</pre>
<p>3) Load estimate by thermometer.
Where available, remove lifting-eye from motor carcass, fill hole with oil, insert old-fashioned thermometer. If lift-eye hole is unavailable build temporary reservoir with putty, or other suitable material, add oil, then insert thermometer.
<p>Regards,<br>
Phil Corso, PE<br>
(Boca Raton, FL)<br>
[[email protected]]<br>
<pre>
</pre>
<p>Regards,<br>
Phil Corso, PE<br>
