What is carrier ring in differential pressure type Flow Meter? What is its advantage?
A Thread Starter A.Venkatesan Jan 2, 2003 #1 What is carrier ring in differential pressure type Flow Meter? What is its advantage?
J Jeff Owens Jan 5, 2003 #2 Some meters use a fitting that has a removable carrier. The carrier holds an orifice plate that can be changed as required, without unbolting flanges or moving the pipe. For an example and explanation, see http://www.daniel.com/products/gas/Orifice/Simplex/Productdetail.htm
