I am using a SCP scailing block to take an input scaled min 4000 to input max. Scaled min is Zero and max is 5000 output is to N7:24.
Using a GEQ block Source A is a N7:24 register Source B is N12:6 set to pass power at 250. My problem is that the GEQ block passes power at 25 instead of 250. This has me scratching my head since this is setup using interger values. The PLC is a SLC 5/05. Any help would be appeciated.
