Hello, I have an Intouch app running on a Windows 2000 Server + Insql Server 8.0 + Intouch 8.0. My application reads (and storage into InSQL) values from 40 Profibus DP Slave devices (Socomec Diris Ap) using 2 Applicom Cards (PCI 1500 PFB). Intouch communicate with these cards using an Applicom DDE-Suitelink Server "PCDDEIO.EXE" (configurate Access Names to use Suitelink) My app is running well but sometimes, every 2 or 3 days, communication between DDE Server and Intouch stops; I can see values changing on the Applicom Console (I'm sure the boards are running well) but the same values don't change in Intouch. If I reboot averything starts well again but after others 2 or 3 days.... In the logger I read
"/Info - Suitelink Stream communication failure receiving from ENERGY-SERVER InSQLData: Connection for PCDDEIO from 127.0.0.1 went away, app closed connection ? (WSAECONNRESET) ( 10054)"
Does anybody know what could be the problem ? Thanks
