Recently we have upgraded a 140 NOE 771 00 to kernel+executive version 3.0.
Since that change we have found that the MSTR tasks stopped working.
The project is programmed with Concept v2.5 SR2. We use both Ethernet IO Scanner to aquire data from 10 Momentum I/O bases with 170 ENT 110 01.
In the other hand, we have three Modbus to Ethernet Bridges (174 CEV 300 20). Each Modbus network has 10 slaves, the communication routine is written as a cycle for each bridge/network. 1st slave is polled, then 2nd slave, 3rd...
With only 1 bridge routine programmed, the communication works fine, but when we use the three MSTR routines, the MSTR block starts giving errors and answering the hex status code: 5050!!!
Thanks in advance.
Braulio
Thanks in advance.
Braulio
