I would like to know if someone of you has had the same problem. Without any apparent reason the PanelView sends the error code 637 "Communication driver failed, contact technical support". The PanelView 600 has Ethernet communication and it is Touchscreen. I would appreciate your help.
Thanks.
Thanks.
