visual basic.net and asyncread
dale
<p>Does anyone have an example of doing a simple read of 2 or more integers from an Allen Bradley SLC or controllogix controller?
<p>I can read data using the addhandler(datachange) - but I can't seem to get an asyncread to work. Apparently I'm not getting my system.arrays for the serverhandles and errors configured correctly.
<p>I get a "Specified array was not of the expected type." on the asyncread.
<pre>
Imports RsiOPCAuto
Public Class Form1
Public WithEvents oServer As RsiOPCAuto_OPCServer
Public WithEvents oGroup As RsiOPCAuto_OPCGroup
Public oItem1 As RsiOPCAuto_OPCItem
Public oItem2 As RsiOPCAuto_OPCItem
Public oItem3 As RsiOPCAuto_OPCItem
Public oItem4 As RsiOPCAuto_OPCItem Private Sub Form1_Load(ByVal sender As Object, ByVal e As EventArgs) Handles
MyBase.Load
oServer = New RsiOPCAuto_OPCServer
oServer.Connect("RSLinx OPC Server")
oGroup = oServer.OPCGroups.Add("TestGroup") oGroup.IsActive = True oGroup.UpdateRate = 500
oGroup.IsSubscribed = True oItem1 = oGroup.OPCItems.AddItem ("[Dale99]N7:0", 1)
Dim arHandles(9) As Object
Dim arerrors(9) As Object
Dim arTransID As Integer
Dim arCancelID As Integer
Dim i As Integer
i = 0
arHandles(i) = Group.OPCItems.ServerHandle
oGroup.AsyncRead(1, arHandles, arerrors, arTransID, arCancelID)
</pre>
Andrew Smith
Did you get an answer? I have exactly same problem. VB.net using RSiOPCAuto.dll. The problem has to do with base 1 arrays I know. Did you find a workaround?
Cheers,
Andrew
[email protected]
<p>I am very close to a solution. This should work, but unfortunately, I have an error: "Value does not fall within the expected range" on all calls. Can someone let me know which value is out of range?
<pre>
Private Sub cmdAsyncRead_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdAsyncRead.Click
' This function demonstrates how to perform an OPC Group Asynchronous Read operation.
' The data is returned in the callback function MyOPCGroup_AsyncReadComplete
Dim lNumitems As Long
Dim arHandles() As Integer
Dim arErrors() As Integer
Dim lTransID As Long = 1975
Dim lCancelID As Long = 1
Dim myOPCItem As OPCItems
Dim i As Integer
Dim tmp As Integer
On Error GoTo ErrorHandler
txtStatus.Text = "OPC Group Async Read in progress ..."
'specify number of elements
lNumitems = MyOPCGroup.OPCItems.Count - 1
ReDim arHandles(lNumitems)
ReDim arErrors(lNumitems)
' Dimension server handles array
For i = 0 To lNumitems
'pass in server handles
tmp = MyOPCGroup.OPCItems.Item(i + 1).ClientHandle
arHandles(i) = MyOPCGroup.OPCItems.Item(i + 1).ClientHandle
arErrors(i) = 0
Next 'i
' perform async read
MyOPCGroup.IsActive = False
MyOPCGroup.AsyncRead(itemCount, arHandles, arErrors, lTransID, lCancelID)
' check for error in passing parameters to server
Exit Sub
ErrorHandler:
MsgBox("Async Read Error: " & Err.Number & " " & Err.Description & ", " & Err.LastDllError)
End Sub
</pre>
W
Did you get your problem worked out? If not E-mail me and I will send info on what you want. My E-Mail: tom1fox @ suddenlink. net
Your example will probably work if you change the i value to a 1. OPC just wants all values at the number 1 index of the array. I didn't test your code to see if it would work, but, thats what it looks like to me. I have E-mailed a demonstration VB.Net program to you. If anyone would like to have it, simply send me an E-Mail and you will get it.
[email protected]
New E-mail Address- [email protected]
