L
I have to purchase a new load cell for an experimental application.
The rated resolution of all the load cells I have considered is infinite.
The output is 2mV/V and the capacity I need is 5 lb.
In one of the load cells data sheet there is a 'total error' expressed in porcentage of rated input, while in most of the other ones there are three or more different values: Hysteresis, Non-linearity, Non repeatability and sometimes Zero balance. All of these are expressed in porcentage of full scale output.
In order to compare the accuracy of these load cells I would like to know how to calculate the total error of each of them. I suppose in fact that the total error is a good expression of the accuracy of the transducer.
Looking on the web I understood the meaning of these words (repeatability, linearity etc..) but I couldn't find how to put them together -if possible- into a sinlge significant value.
Hope you can help me with this.
Libero
Libero
